Sun, Dec 22, 12:17 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 20 7:20 am)
Subject: Program to check for misdirected pointers to .OBJ files?
Anthony Appleyard ( ) posted Wed, 31 August 2005 at 5:26 PM · edited Fri, 13 December 2024 at 12:43 AM
A while ago someone wrote a program to go through .CR2 and .PP2 and .PZ3 etc files and look for and correct misdirected pointers to texture map files. It would be useful if this program could be adapted to also check the lines that point to.OBJ files.
MachineClaw ( ) posted Wed, 31 August 2005 at 5:29 PM
Correct Reference application by hogwarden I thought checked all poser related references. In freeStuff here. Does it not check OBJ files?
Khai ( ) posted Wed, 31 August 2005 at 5:31 PM
it does :)
AnneCHPostma ( ) posted Wed, 31 August 2005 at 6:14 PM
Useful but a bit to expensive for me right now. Got it bookmarked though.
MachineClaw ( ) posted Wed, 31 August 2005 at 7:14 PM
Correct Reference is free. Correct Reference Pro is a pay product.
momodot ( ) posted Wed, 31 August 2005 at 7:14 PM
Poser File Organizer. Is that cheaper here at the Market Place?
shogakusha ( ) posted Wed, 31 August 2005 at 9:17 PM
I don't think Correct Reference is in free stuff anymore. I cannot find it.
MachineClaw ( ) posted Wed, 31 August 2005 at 9:38 PM
There is a link in freestuff, but it's hogwarden's site link and seems free correct reference is no more now that CR PRO II is out now. dunno. have to be reg'd on the site and I didn't want to take the time.
Anthony Appleyard ( ) posted Thu, 01 September 2005 at 12:03 AM
Attached Link: http://www.altavista.com
Where can I download "Correct Reference"? I have just searched on this link and:- **"correct reference" hogwarden** found nothing. **hogwarden** drowned me in 11300 results. **"correct reference"** found 98500 results, mostly (as expected) irrelevant.
12rounds ( ) posted Thu, 01 September 2005 at 1:03 AM
I wrote a straightforward, but involved tutorial on listing OBJ files not referenced from pp2 or cr2 files. I posted it at rendervisions a over a year ago under a title with "Runtime lessons" or something like that. It is in essence a simple set of command line commands executed in Windows command box, but does require the installatin of a couple of free GNUWIN32 programs that are ports of Unix tools to Windows. It does nothing to correct anything, but just lists files that are not referenced. I needed to do this while cleaning my hd at one time. It may or may not help you with what you are doing.
pdblake ( ) posted Thu, 01 September 2005 at 5:23 AM
Poser Product Packager in the MP will also do that.
HandyGM ( ) posted Thu, 01 September 2005 at 10:16 AM
If you work up a list of all the conversions and checks you want, in the right order, I have a programmer friend that would probably make this into a Python script for you.
momodot ( ) posted Thu, 01 September 2005 at 11:02 AM
A python script for straigten things out would be nice but the coolist python would be one that would load .cr2 or .pz2 and set No_MAP or simply ignore any missing textures... I am always crashing out of Poser when I load something into a scene that I did no know was missing refered to textures.
raven ( ) posted Thu, 01 September 2005 at 1:11 PM
Attached Link: http://www.hogsoft.com/index3d.htm
Have a look here for Correct Reference.
whbos ( ) posted Sun, 04 September 2005 at 11:03 AM
Recently I was in the need to at least try out Hogwarden's free Correct Reference program and found that it was no longer available as a free utility and don't have the funds right now. Instead, I've been going through hundreds of PZ3's to convert them to PZZ's (11 DVD's squeezed into 1) while going through the time-consuming process of matching OBJ's and JPG's to newly created Runtime folders that didn't exist when these PZ3's were created (I was only using one Runtime at the time). In my opinion, even though it is taking more than a week to do this I am also finding a lot of missing files that need to be there such as hair, figures, and prop geometry and textures. I'm not sure if Correct Reference will give you some sort of missing file listing that would be useful for this since I didn't get to try the freebie and the demo doesn't seem to be available. It also helps to have a recent backup of your entire Runtime folders.
Poser 2, 3, 4, 5, 6, 7, 8, 9, 10, Pro 2014, 11, 11 Pro
Mystic-Nights ( ) posted Mon, 05 September 2005 at 8:25 AM
I have Correct Refernce 1.1 which is the freeware version. According to the license file it can be freely re-distributed. If you need it let me know.
