Mon, Feb 3, 11:24 PM CST
Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
Subject: Quick Guide to Making a Puzzle
Onslow ( ) posted Fri, 02 September 2005 at 4:28 AM · edited Mon, 03 February 2025 at 5:00 PM
A quick guide to making Jigsaw Puzzles in PS.
Open your image get it adjusted how you like it and resize to finished sized.
Open a New image - this will be the baseboard - make it larger than the first image, fill it with whatever you want your baseboard to be ( wood etc.). I have just used plain white.
Holding down Alt click and drag with your mouse the first image to make a layer on top of the baseboard image. You can now close the first image.
Go to the History Palette and make a snap shot by clicking on the camera icon.
Highlight Layer 1 (your picture) in the layers palette.
Go to Filter - Texture -Texturizer. In the drop down box put Load Texture.
A window will open - go to your Adobe program folder - Presets folder - Textures folder - and find a file named Puzzle.
Adjust Scaling and Relief to suit. Click OK.
[See Attached Screen Shot]
Message edited on: 09/02/2005 04:32
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies live;
Their heads are green, and their hands are blue, And they went to sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
Onslow ( ) posted Fri, 02 September 2005 at 4:28 AM · edited Fri, 02 September 2005 at 4:34 AM
Continued:
With the History Brush (snapshot highlighted) carefully make the edge pieces into proper edge pieces removing unwanted joins.
Zoom in to one piece of the puzzle and use the Magnetic Lasso tool to select a piece (taking care to get the shadows on the right side).
Ctrl X (copy)
Ctrl V (paste onto New Layer)
Click the Eye icon on the Layers Palette next to the Background & the Picture layers to turn visibility of these off.
You are left with the piece on an Opaque layer. Click the Lock Opacity icon at the top of the Layers Palette.
Using a small Air Brush (Colour black, Opacity 50%) Go round the edges of the piece to give it darker edge. This gives it depth when viewed.
Click the 'F' icon at the bottom of the Layers Palette and give it a Drop Shadow.
Click the Eye icon to turn back on you Background and Picture layers.
Highlight the Piece layer and got to Edit - Transform - Rotate and rotate to suit.
Move it into a position you like.
(Repeat for as many pieces as you want to remove.)
Highlight the Picture layer and add a Drop Shadow.
Make a Duplicate image and save it with all the layers.
Flatten your image and save for the web.
It sounds a lot more complicated than it is, give it a try.
Message edited on: 09/02/2005 04:34
Edward Lear
tibet2004uk ( ) posted Fri, 02 September 2005 at 7:17 AM
It does indeed! O_o Thx Rich for that mini tut! Didn't get everything but hey! ;) LOL!
TwoPynts ( ) posted Fri, 02 September 2005 at 9:41 AM
Cool, will have to give that a try!
Onslow ( ) posted Fri, 02 September 2005 at 10:31 AM
Suspect the shortcuts are different on a mac ? Edit message 2 - should read: Ctrl X = Cut [which is why the picture has to be a layer and not a background so pieces can be cut out]
Edward Lear
bsteph2069 ( ) posted Fri, 02 September 2005 at 7:32 PM
Ahhhh. Just up my alley. I also have a program just to make jigsaw puzzles. However they have a nice enlargement program. WWW.STOIK.COM Bsteph
maggiemai ( ) posted Fri, 02 September 2005 at 8:33 PM
That's pretty cool...thank you so much for sharing it!! :-)
Love, Light and Laughter  ~ :-)
kimariehere ( ) posted Fri, 02 September 2005 at 10:51 PM
really cool work ps?..paintshop or photoshop? thanks!
kimmers ♥ :O)
Onslow ( ) posted Sat, 03 September 2005 at 1:45 AM · edited Sat, 03 September 2005 at 1:52 AM
Photoshop
If you have PS Elements you do not have a history brush. Do everything the same just ignore that bit and use a clone brush to remove unwanted joins from edge pieces.
Message edited on: 09/03/2005 01:52
Edward Lear
cynlee ( ) posted Sat, 03 September 2005 at 2:49 AM
thanks Richard!! will add to links..
