Sat, Feb 8, 12:59 AM CST
Subject: Vue 3 viewing problem HELP please!
Silgrin ( ) posted Sat, 03 September 2005 at 9:24 AM ยท edited Sun, 20 October 2024 at 4:30 AM
A problem with views in Vue dEsprit 3 Mover. I got the free version and I got stuck with sth I cant solve even with the help. When I create the terrains, in some moment the viewing mode is changed in such a way that I no longer can see the camera and terrains simultaneously; instead, only the currently selected item (either camera or all the terrains) is visible. Whats even worse, the visible item is always in the center of all views, irrespectively of its actual positions. I also can no longer see the terrains in the camera view (its empty and it renders only water). This problem makes me unable to position the items relatively to each other and to use the camera! I have no idea why is the viewing mode switched and how to go back to the initial method which displays everything on its position, as for all 3D apps. PS 1. All objects are on the first layer. PS 2. This is my first post in the Vue forum. Hi everybody:)
Polax ( ) posted Sat, 03 September 2005 at 6:16 PM
Hi :) There is an option that can be unchecked in Files/options it is: "center views on selected objects" but it should not change the camera view so maybe there is smthg more but I cannot see what. anyway, you can try unchecking it and see if things get better ...
