Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Another note re. destro's advice: If you go that route, there are a few things you can do that may help things along: - Scale the square so it has the same size (in poser units or whatever you're currently using) as the picture is in pixels (that'll retain the pic's proportions). - Use a single-sided square (not the 2-sided one). - Move the square waaaay back in z to avoid casting shadows from the foreground onto it. Plug the image into the ambient channel, not the diffuse (you don't want it affected by the lights, do you?) - Use the main scale (not scale x or whatever) dial of the square to get it to fit. You may also have to rescale your display window and/or render window. Cheers, Diolma (I've probably left something important out, it's a habit of mine..)
Dammit, I knew I'd left something important out...
Turn the diffuse colour off completely (make it totally black or set the value to 0) -- errm, or is it the other way round? Make it totally white.. I think it's black, long time since I did this (at least 2 months ago)..
Cheers,
Diolma
(Wonder what else I've forgotten..)
Message edited on: 09/05/2005 14:58
Greetings, I have a very annoying Problem when i add a backgroundpicture in poser. Whenever i add a pic that is e.g. 800 x 600 poser askes me if i want to resize the window to match the background. I click yes and in the preview all looks fine, but as soon as i do a firefly final render, the background picture is compress to the former size of the preview window... any idears why that is so?
