Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 01 5:26 pm)
Attached Link: My workflow (8megs)
Just animate the indivdual scenes and edit them together in any video editing program i am about to start a new animated film using poser figures rendered in carraraTo make DVDs, I use the following steps:
Render animated scene(s) as individual images, using 640x480 resolution and PSD format.
Compile into clips using Quicktime Pro "image sequence" loading.
Combine clips using cut and paste within QT Pro.
Save animation as standalone MOV file.
Burn to DVD using Ulead Movie Factory 2, which imports QT MOV files.
If I need to match up sound effects exactly with video track, I import an AVI version of the animation into a video editor.
Good luck...
640x480 is not the dvd size, when it is converted to the dvd the ulead program probably resizes it to fit, giving you a poorer quality picture. For pal the correct size is 720x576 but I dont know the ntsc size, it should be easy to find out. Rendering to the correct size shouldn
t take much longer to do.
Does anyone know where I can get some good tutorials on how to make a movie in Poser 6? Thanks in advance. Adrian
