Attached Link: http://visibleearth.nasa.gov/
The image above shows some of the 30 or more Hurricanes I downloaded- many at 4000 x 4000 and some up to 8000 x 8000,
and they are great for importing into Vue's Terrain Editor.
Just SEARCH for "Hurricanes", or "Clouds" and you will have LOTS to choose from...
Load a Terrain. Then scale it up higher and SAVE it!
This will keep Vue from potentially crashing when you get up to 4096 x 4096. You don't have to go that big, but I do all my terrain stuff at that resolution for best results.
Load one of the Mega 4K or 8K Hurricane photos and apply it at 100% blend. You might also want to have a water plane under it as it looks better that way.
I found using MILK as a material is nearly ideal as it renders fast. Mixing in some Impure Glass, or tweaking the fuzziness can look good too, but it increases render time by almost 10X (not good).
Obviously the Hurricane could be easily animated in Vue just by having it slowly twist around. Make some animations and maybe a TV weather channel or someone making a Hurricane documentary will give you a job.
I'm sure a LOT of people will be making Hurricane documentaries in the near future!
Personally, I recommend editing them all to squares (5K, 6K up to 8K resolution) as they map more easily that way.
Great scenes :) Two suggestions : - Did you try with Volumetric or Fuzzy materials to give them a more 'cloudy' look ? - How about making the base of the clouds transparent and displaying a satellite map of the area under the clouds ?
Nevermind the fuzziness... I just noticed in your comments that you gave that a try :)
![file_289874.jpg](https://live.cdn.renderosity.com/forum/threads/2398903/file_289874.jpg)
Above, Hurricane Douglas in Vue...With the recent disaster caused by Mega-Hurricane Katrina I thought some out there might be interested in how to get a reasonably decent looking Hurricane into Vue. I had originally been exploring how to get US Weather Data into Vue (the kind you see on TV when they show animated Hurricane models) and stumbled upon a much more simple idea-using Vue's Terrain Editor.
The next problem was WHERE to get good shots of Hurricanes.
Surprisingly, places like NOAA and the US Weather Service had only small black and white photos on their websites- and then they always had white Long-Lat lines, etc. on them.
