Thu, Feb 6, 7:08 PM CST
Subject: Hey. Super quick heads up. Wings update just made available early this morning
waldomac ( ) posted Mon, 12 September 2005 at 8:33 AM · edited Thu, 30 January 2025 at 7:17 AM
Bjn's message: "... I am happy to say that Giniu/GinMajster has joined the Wings team. Welcome! And here is a new Wings release. Enjoy! /Bjn - New settings to workaround invisible edge problems in (Edit|Preferences; tab Misc; bottom of dialog box). If you have problems with disappearing edges, try higher values in the two fields. (Too high values will cause other problems, so it is best to increase the values gradually.) Please post the results in the forum. (By Dan.) - The pre-built Wings packages now use Erlang/OTP R10B-7. - Fixed a bug that made it possible to turn on magnets for commands that were not supposed to take magnets; in most cases causing a crasch. (E.g. activating the Extrude command by Alt+MMB clicking.) (Problem reported by GetaVe.) - The file dialog for Linux (and optionally Macintosh) is now translatable and has been translated to Polish. (By Giniu.) - New Tesselate|Untriangulate command. (By Trepan.) - The Edge Loop command is now "stoppable"; for instance, if two edges are selected, the command will select only the edges between them (going the shortest way). Same for Edge Ring. (By Dan.) AutoUV/Snap (by Dan): - Cylinder and Sphere mapping work better in some cases (if cut properly). - Miscellanous bug fixes in Move/Scale in snap image. Yafray/Toxic (by Raimo): - Moved OS job and rendering job functionality out from wpc_yafray and wpc_toxic to the new module wings_job, to facilitate more rendering plugins. There are new preferences in the User Interface tab of Edit|Preferences. - Yafray: Added .hdr rendering output file format. Restructured the Render/Export dialog and implemented the AA_jitterfirst, clamp_rgb, alpha_premultiply, and alpha_backgroundmask settings. Implemented the new Depth-Of-Field parameters. Removed the already defunct antinoise filter. Implemented occlusion mode for pathlight, and maxdistance parameter for pathlight and hemilight. Corrected a bug reported by Oort: when using EXR output format .exr filename suffix was not default. Added material dispersion. Added spherelights. Added visible ligths (for point-, soft- and spherelights). Moved output format parameters to plugin preferences, and introduced a possibility to use an external viewer to view e.g .exr files after rendering. Added absorption parameters to the generic shader. Added .exr output file format support. Added new camera types ligthprobe and spherical. Added SubSurface Scattering block shader. Oh, and I forgot, last version I added a checkbox for keeping the intermediate .xml file when rendering. Added .hdr rendering output file format for wpc_yafray."
scoleman123 ( ) posted Mon, 12 September 2005 at 9:08 AM
Wow, sombody other than Drac has wings news.
 facebook.com/scoleman123
foleypro ( ) posted Mon, 12 September 2005 at 10:27 AM
Hmmmm... No link...?
waldomac ( ) posted Mon, 12 September 2005 at 10:37 AM
Attached Link: http://www.wings3d.com/
Here's the link. Go to "development release" and pick your poison. My apologies to Drac if this is his sole bailywick. :) Just got caught by surprise when I checked and found the new update, so I got overly enthusiastic.
danamo ( ) posted Mon, 12 September 2005 at 12:41 PM
Thanks for the heads-up.
bandolin ( ) posted Mon, 12 September 2005 at 1:52 PM
Dosen't work in OSX 10.3.9. Tried it, craps out everytime.
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
