If it is a very recent purchase from Zygote, the zipped files they give are now put into a directory C:Curious Labs - instead of the previous directory C:Program FilesMetacreationsPoser 4, etc so you have to move them by "hand" as it were. You are unlikely to be "out of memory", this is a "wrong" message. I usually find that this is because I have not got the object files into the right place and/or because the directory is not spelled correctly - it is case sensitive.
RPS/bromyaur : With ALL of Zygotes .EXE installers you can choose where EXACTLY your POSER4 directory is located. So if you put in (or browse to) the right directory it should be putting the OBJ in the right place. This definetely sounds like a misplaced OBJ error. One way you can check is to open the figure file in a text editor (like notepad or wordpad) and one of the first lines indicated exactly where it expects to find the OBJ.) -Tim
I just bought a couple of Zygote animals, Buck, Camel. When I try to open them I get 'cannot open resource file buck obj etc..." then the next window that pops up is "you are out of memory, save your work and quit soon. You may also have allocate more memory to Poser" I have an extensive libray of characters and animals and they all seem to open with no problem, I believe I have also seen this with one or two more animals also. What I dont understand is that some of my other characters and animals appear to be more complex than the ones I am having problems with.I have also ctrl-alt-del and shut down almost everything to free up resources. Is it possible that some of the geometry file, obj's, textures have not installed into the proper directorys? Or any other ideas? I have a p2 400 with 128 megs of ram. 8.4 gig hd with 3 megs free and am running Poser 4. This problem seems to manifest with the Zygote animals only, I have several Zygote characters and people, and all work great. Any suggestions would be appreciated.
