Sat, Feb 15, 4:12 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Python2.4 breaking PoserPython?
face_off ( ) posted Mon, 19 September 2005 at 5:22 PM · edited Thu, 13 February 2025 at 4:20 PM
Hi I've have a couple of support calls from people recently where they have installed python2.4, and then PoserPython doesn't run at all (not even an error msg), or it runs, but tcl is no longer recognised. I haven't installed python2.4, and was wondering it anyone else had had this problem. A workaround is to remove the PYTHONPATH environment variable.
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
nruddock ( ) posted Tue, 20 September 2005 at 2:10 AM
Running multiple version requires you to take control of how the environment variables get set.
ISTR that there is an option when installing to not have them set by the installer.
BAT files can then be used to setup the environment for different versions
tromnek ( ) posted Tue, 20 September 2005 at 10:43 PM · edited Tue, 20 September 2005 at 10:44 PM
You could probably hack PoserPython's "site.py" to see if PYTHONPATH is in the environment. If so remove it from os.path
something like
try: sys.path.remove(os.environ["PYTHONPATH"])<br></br>except: pass
might work
Message edited on: 09/20/2005 22:44
face_off ( ) posted Tue, 20 September 2005 at 11:08 PM
Thanks for the responses. Much appreciated.
Blog
Facebook
