Sun, Feb 2, 3:10 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: Flame or fire animations?
Peacer ( ) posted Tue, 20 September 2005 at 12:38 PM · edited Sun, 02 February 2025 at 3:07 PM
Hey, I am wondering if I can get my hands on some sort of flame/fire animation to use in Poser 4? I tried out the UltimateFIRE free candle flame, and while it looks absolutely terrific, it looks as though it is meant for single frame renders only. Unfortunately, I need that flame to be dancing, otherwise it wouldn't look right. Any help would be greatly appreciated. Thanks!
nruddock ( ) posted Tue, 20 September 2005 at 1:29 PM
I think you need at least P5 to be able to animate textures.
Peacer ( ) posted Tue, 20 September 2005 at 1:54 PM
"I think you need at least P5 to be able to animate textures."
Well the way I've been doing it is just simply applying textures to different squares, then moving them in the 3D space in such a way that it appears to animate. Each square must be identical in size, and be place in the exact same spot when in frame (though it doesn't matter where they are out of frame), then just replace them one frame at a time to create an animation.
So I guess if I had multiple frames of that flame flickering, I could do that, but the package only comes with one texture for the flame.
randym77 ( ) posted Tue, 20 September 2005 at 2:05 PM
Maybe you could make your own textures. Take that one flame texture, and tweak it in Photoshop or whatever. Make it bigger, or smaller, fatter, thinner, alter the color to redder or whiter, etc.
Peacer ( ) posted Tue, 20 September 2005 at 2:25 PM
Well I could definately do that (in fact, I thought about scaling it in Poser to create a flame animation), but it doesn't have that realism effect I'm looking for. I need the flame to be in different positions to look as though it is "dancing", like a real flame might... at least when in mildly windy conditions. I actually want to use it for a torch effect, so the flame needs to be a little more powerful and actually move around. I'm currently searching for free, high res stock footage of flame animations... so if anyone knows where I can get them, PLEASE let me know! Thanks!
Little_Dragon ( ) posted Tue, 20 September 2005 at 2:26 PM
I have a 75-frame looping AVI, if you want it. Load it into [VirtualDub](http://www.virtualdub.org), and you can export an image sequence.
Peacer ( ) posted Tue, 20 September 2005 at 2:33 PM
Hm, that might work. I would definately have to cut it down to about 20 frames, then just create some trans maps in Photoshop. I'll give it a try. Do you have any other flame animations? Thanks
Little_Dragon ( ) posted Tue, 20 September 2005 at 2:42 PM
None at the moment. But I can create all manner of flame and smoke effects in particleIllusion. It's the same software that JPeter uses for his video clips in the Marketplace. I don't really want to cut into his profits. He's charging next-to-nothing for them already.
gmadone ( ) posted Tue, 20 September 2005 at 3:53 PM
This is a looping texture made with P5.
Latexluv ( ) posted Tue, 20 September 2005 at 5:14 PM
gmadone, I'd be interested in that P5 Material there. I've not seen any very satisfactory flame/fire P5 Shaders yet.
Weapons of choice:
nruddock ( ) posted Tue, 20 September 2005 at 5:31 PM
With the right Shader recipe you can get a wide variety of flame types.
Are you looking for a single flame or something larger ?
Latexluv ( ) posted Tue, 20 September 2005 at 6:09 PM
Single or multiple flames (candle to bonfire). I've got a tutorial from Runtime DNA about glow effects and the probelight by I cannot find the accompanying zip of base material shaders that were supposed to go with the tutorial. I'd rather have the shaders, but I'll take screen shots of shader node set ups. I've got a folder going on screen shots.
Weapons of choice:
randym77 ( ) posted Tue, 20 September 2005 at 7:10 PM
That is really neat. I didn't know the Material Room could do that. Won't help Peacer, though. He's using P4.
Peacer ( ) posted Tue, 20 September 2005 at 11:23 PM · edited Tue, 20 September 2005 at 11:24 PM
Hey guys,
I really appreciate all the great replies, but I decided to tone down the flame a bit, and therefore it becomes less animated. I just purchased a flame package from the Market Place for a mere $6, and it's got some great glow effects I can use for torches (while UltimateFIRE is good for candles), so I just tweak the flame to have a pulsating glow effect instead. With P4, that's probably my only route unless I spend hours hand-animating flame textures... I really should upgrade my Poser package!
Message edited on: 09/20/2005 23:24
svdl ( ) posted Wed, 21 September 2005 at 11:29 AM
Opps. Poser 4. Then you can't use an .avi or .mov as a texture. A pity. Jepe has some neat fire animations for sale (Jepe's Movie Props).
My gallery   My freestuff
LostinSpaceman ( ) posted Wed, 21 September 2005 at 12:05 PM
Is there a tutorial on making those shader flame animations? There should be one if there's not!
nruddock ( ) posted Wed, 21 September 2005 at 1:54 PM
No tutorial, the best I can manage is to post some variations for people to play with.
