Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 12:25 pm)
Miki installs into her own folder. It's called Miki1020Pack, or something like that.
Find the Miki folder. (It should be where you installed it - the main Poser folder, probably.) There's a runtime folder inside the Miki folder. Move it in the Poser folder (or whatever folder that contains the runtime you want her in). You should see her in your library then.
I just got Poser6 upgrade from poser5. after i upgrade to poser6 i downloaded and install miki. i can find it in the folder, but when i go inside to use the software , i am unable to locate miki fiqure in fiqure libaries. Has anyone else having this problem? If so how did you fix it? any help will be extremely apperciated.. Tom
