Thu, Jan 30, 9:52 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: poser morph
brianhen ( ) posted Fri, 23 September 2005 at 11:52 AM ยท edited Thu, 30 January 2025 at 9:42 AM
What is the best way to get clothing to fit right on a figure?? I have a v3 that I morphed into a little different figure. The clothing doesnt seem to fit right now with the changes. I changed some of the settings in the clothing properties, but would it be easier to go back and change the morphs on the v3?? thanks
thixen ( ) posted Fri, 23 September 2005 at 12:08 PM
It depends on what your looking for. The best way to do it and keep the morphs would be to post work it using cloning tools and the such. If you're a purist and don't want to do post work (or dont have the utilities to do it) then tweaking the V3 morphs would probably be easier, unless you can get away with hiding the body parts that are giving you the poke through. A third way would be to export your clothing in the Zero pose and then reimport them as props and use them as dynamic cloth. There are tutorials on the net on how to do this. This doesn't work with all clothing though.
xantor ( ) posted Fri, 23 September 2005 at 12:30 PM
The tailor can copy morphs from one figure to another and wardrobe wizard is good for making morphed figures clothing fit, but neither of these programs is free.
steveshanks ( ) posted Fri, 23 September 2005 at 1:02 PM
Get "Wardrobe wizard" and "Tool collection for poser" (in store here), use WW to fit the clothes to the morphed figure, then export the clothes obj (uncheck all boxes) then use the "add morph" app from "Tool collection for poser" to add the full body morph you just created, your cr2 will now have a full body morph to fit the new figure....Steve
decadre ( ) posted Fri, 23 September 2005 at 11:21 PM
Are these the programs? http://market.renderosity.com/softgood.ez?ViewSoftgood=8357 http://market.renderosity.com/softgood.ez?ViewSoftgood=37406
steveshanks ( ) posted Sat, 24 September 2005 at 3:28 AM
No you want Wardrobe wizard from http://www.philc.net/ go to catalog/utilities, then the second one you mentioned http://market.renderosity.com/softgood.ez?ViewSoftgood=37406.....you can actually export each body part, then import and spawn a body morph but it takes so long at may send you insane so Tool Collection for Poser is a good idea......PWizard, is a great app BTW, just not needed for this task.......Steve
