Attached Link: http://www.runtimedna.com/mod/bcs/index.php?ViewProduct=762
... I buy all my Grass here...Actually- if you go over to RDNA and search under artist Traveler, you will find a really huge variety of grassland
models- he has made plant and grass models out of nearly everything I can think of.
Veritas777, I went to RDNA and sawTravelers "The Fields". It says this is a Volumetric Field Figure with Movement and Height Morphs * 3 Texture Options + Mixed MAT files Features * 3 Material Zones for Mixed Fields * Wind Movement Morphs * Height Morphs * Need a larger field? Bring in a few more - Tiled design. But how would I use this in Vue and this isn't a model or is it? If I have a large hill and want to cover it in this grass will it conform to the hill and how? Sorry but I am just a little confused as to how this works.
To use the morphs you would have to pose it first in Poser and then import it to fit your scene. Otherwise, you will just import it as a Pz3 (or Pzz) and it will be flat- and you can take it from there. Because of the nice details, I use it as a Fore-Ground model, and fake the background fields with Vue materials. If you have Vue 5 Inf- you can use it as an Eco-Systems object and have it repeated over a very large area using "instances". Another nice thing about Traveler's props are the very nice texture maps- which can be applied to other objects and scenes in Vue.
