Foxseelady I have the same problems with M3 and Matt when making characters the way I want them, then save them for later use. When loading the character it seems it doesn't want to go back to where I had saved them. I don't know what causes this either however, when I load both the body and head INJ, it goes back to the way I had saved it originally. I hope this helps. Adrian
Strange, I never had that happen in Pro Pack. Mayhaps the morphs aren't being saved in the cr2 file for some reason? Try running Dial Cleaner (free at DAZ) on the cr2 then re-load the figure. If the morph dials are gone, that's the problem. The external morphs feature is an anomaly indigenous to P6. Anyway, good luck. I hope you figure it out.
I have a character, for V3. Worked long and hard on her, love her, saved her as a character and a pose and a pose inj just to be on the safe side (maybe a bit of everkill but). Despite all that, I load V3 (the same on I used originally) and "NONE" of those work on her she stays plain old Vicky.....ARGhhhh The dials say they are turned to where they should be, but she doesn't change. Does anyone know why? What happened? Most importantly how on earth to fix it?? If worse comes to worse I will write the dial settings all down and re-turn everything but man oh man I don't want to lol.
