Mon, Jan 27, 8:14 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 5:49 pm)
Subject: How do you apply textures in Pose 6?
moushie ( ) posted Tue, 27 September 2005 at 12:21 PM · edited Tue, 01 October 2024 at 8:31 AM
How does one apply textures in Poser 6? I can't get out of the default textures. The 380-page (PDF) manual is no help.
thixen ( ) posted Tue, 27 September 2005 at 12:34 PM · edited Tue, 27 September 2005 at 12:36 PM
depends on what you're looking for.
If you're looking for applying full already made textures then for the majority of the stuff it's the same as P5 - go to poses and look for the MAT poses and click. A few forward thinking folks (including the included content that came with P6) have started to use the material room materials though and for those you go the the material room. The library should refresh to the materials folder automaticlly and then you browse through and click like before. If you're looking to make your own and apply them, then you have to set up a shader tree with shader nodes.
To learn how to do that you need to read some tutorials. I suggest Dr. Geep's stuff and Stewers
Geep's can be found by clicking on the backroom (Poser Forum Logo) link and Stewer's is here.
Stewers
These guys are guineses when it comes to 3d apps and explaining them to people so you can't go wrong with these guys. Just Say Nay to NaySay
Message edited on: 09/27/2005 12:36
moushie ( ) posted Tue, 27 September 2005 at 1:23 PM
Many thanks. I'll study and digest. Not as intuitive as P4!
NaySayGuy ( ) posted Tue, 27 September 2005 at 2:40 PM
Ah herd dat !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
geep ( ) posted Tue, 27 September 2005 at 2:49 PM
......... you really, REALLY don't want to piss off the NaySayGuy. ;=[ (there's no telling what he might do ...)
moushie- You might want to try this. Excerpt from the P5 Material Room tutorial. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
diolma ( ) posted Tue, 27 September 2005 at 2:52 PM · edited Tue, 27 September 2005 at 2:56 PM
Moushie:
If your model is UV mapped and you have a corresponding texture (or set of textures) but no MAT file then:
Go to the Materials room.
Select the model.
Then for each of the materials in the drop-down list for that model:
  • R-Click on a blank bit of the room's background.
  • From the drop down list, select new node->2D textures->image map.
  • When the node appears, click on the image name (at top right of the node, it'll say something like "none" at the moment).
  • When the dialogue appears, you have two choices:
    • if the image has not been loaded yet, click on Browse, then navigate your way to the image and load it.
    • if the image has already been loaded, hit the drop-down triangle to list the loaded images, and select the one you want (if you get both a long name (with a path) and a short name (no path), it tends to be best to select the long one.
Sounds daunting, but once you get used to it its easy enough (if a little tiresome when using V3).
Cheers,
Diolma
Edited to add: If you're going to use the texture again, you can save it in the materials library as a materials collection(?) file (P6's built-in equivalent of the MAT files hack..) Or, of course, you can simply save the model pre-textured into the relevant figure/prop or whatever library..
Message edited on: 09/27/2005 14:56
diolma ( ) posted Tue, 27 September 2005 at 2:59 PM
OOps - X-Post! (Bob, I started B4 you, but finished after (but then I had to type each and every word (many of them twice 'cos I mis-spelled them)..:-)) Cheers, Diolma
Tyger_purr ( ) posted Tue, 27 September 2005 at 3:13 PM
or you can just switch to the "simple" tab (upper left) and not have to mess with the nodes.
My Homepage - Free stuff and Galleries
geep ( ) posted Tue, 27 September 2005 at 4:31 PM
re" " ... switch to the "simple" tab ..." DON"T DO THAT !!! You might get NaySay. cheers, (anyway) dr geep ;=]
@ Diolma ... x-posts ?? No problem. ..... ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
diolma ( ) posted Tue, 27 September 2005 at 4:37 PM
LOL @Geep!! Cheers, Diolma
