Note how BEAUTIFUL the water reflections are when reflecting
more realistic Cumulus Clouds- than just the normal THIN &
WHISPY Clouds often seen in Vue (or Bryce). There is NOTHING
better than some wonderful Cumulus Clouds to make a 3D Picture more ALIVE!
BTW- Everything you see in this little Cloud Tutorial can be
done with VUE 4 and VUE 5- as well as V5 Infinite. I'm not
using the ECO-CLOUDS at all here. So this should work for
everybody out there. The nice thing of course for V5 and V5I
users are the Camera Facing Billboards. That's a big time saving tool when you are moving your camera around and knowing that your clouds are following you around like baby ducks!
Also NOTE the LIGHTING Sliders for DIFFUSE and AMBIENT. These are usually your BEST ADJUSTMENTS when Clouds look Too Bright or Too Dark (other than what has already been mentioned). These are LOCAL Controls on each Cloud Surface. Your GLOBAL Controls are, of course, in the ATMOSPHERE EDITOR.
As you can see, I have generally placed four Cloud SPLATS ("Splats" is the term the "Cloud Pro's" use) into each GROUP- which is saved as a VOB. Later on I may go into much more COMPLEX Cloud Groups- probably adding more Vapor Clouds that will be ROTATED at 45 degree angles- this creates much greater Cloud REALISM...
So- MOVE your lowest Horizontal Cloud Plane up to around 9000 feet or so and the Conflict should go away and the Clouds will all Happily Co-Exist with each other!
I have some even BETTER STUFF coming up to show. (I always think the next thing I'm doing is even GREATER than ever!) I have no plans to sell anything. If anyone else wants to ----be my guest! That's why I'm "publishing" everything I discover- so that other people out there can make some use of it- for fun or profit- I don't care...
![file_294237.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_294237.jpg)
This scene is LOADED with Clouds of various types and on various levels. The top sky is of course standard Horizontally Mapped clouds.In FRONT of those is a Band of Clouds on a single
Vertically Mapped Plane. These were created with the
Flight Sim Cloud Set.
And in the Fore Ground are Procedural Clouds mapped
onto Vertical Camera Facing Billboards. I could have
added MORE Clouds to make it look even better- but this
is just an experimental render to further test my Cloud-Crazed theories.
