Mon, Dec 2, 10:44 PM CST
Subject: Cool app, DOF as post processing! Can poser.....?
operaguy ( ) posted Mon, 03 October 2005 at 7:01 AM · edited Sun, 01 December 2024 at 10:56 AM
Attached Link: http://www.richardrosenman.com/dofpro.htm
I've been looking at the plug-in Depth of Field Generator Pro, (see link above) which batch processes animation frames to add DOF blur, saving render time on the raw frame.
It's also great and appropriate for single frame renders. The combination of AO or IBL and DOF can produce way-cool look and feel.
The author says:
"Most 3D Computer Graphics applications are easily capable of producing depth maps along with the rendered image."
The depth map is a black/white bitmap of the frame, in which the grayscale value of a given pixel translates mathematically to the distance from the camera.
  1. Does anyone know if Poser can produce the depth map?
  2. Has anyone worked with this plug-in, and what is your experience with it.
Thanks,
::::: Opera :::::
estherau ( ) posted Mon, 03 October 2005 at 7:24 AM
Hi, well I render in vue which makes a depth map, and I have purchased that photoshop plug in. I use it on my PC as it's not mac compatible. It works very well. Love esther
MY ONLINE COMIC IS NOW LIVE
blaufeld ( ) posted Mon, 03 October 2005 at 7:24 AM
I don't see its utility... Poser 6 has a DOF function that, for me, works great...
operaguy ( ) posted Mon, 03 October 2005 at 7:36 AM
Could save time, blajfeld, if in rendering a massive animation, the primary render would be speeded up tremendously by not having to calculate DOF. Then, you process your folder of frames for DOF using the plug-in. Also, you might "change your mind" about the intensity of DOF in one portion of your film. You would still have the raw frames un-DOFed to go back to, and you could then reprocess for DOF just for that segment, without having to re-render the full scene. Same with a single frame. Much faster to try out different DOF effects in this plugin than to rerender entire scene with different Poser DOF settings. ::::: Opera :::::
xantor ( ) posted Mon, 03 October 2005 at 8:16 AM
Bryce can render depth maps too, and terragen with a plugin and lightwave.
stewer ( ) posted Mon, 03 October 2005 at 9:52 AM
Attached Link: http://www.stewreo.de/poser/dof_tutorial.html
You can render depth maps using the depth cue effect.
blaufeld ( ) posted Mon, 03 October 2005 at 10:01 AM
Ah... Understood. :)
R_Hatch ( ) posted Wed, 05 October 2005 at 2:56 AM
DOF Pro works very well with Poser. To repeat/clarify the advantages mentioned above, it is much, much faster than using Poser's own dof, plus it's not ultra grainy. Also note that version 3 will be able to do motion blur :D Oh, and the price ain't bad, either.
odf ( ) posted Wed, 05 October 2005 at 8:19 PM
Thanks for the link! I've been using depth maps for post DOF a few times, but without plugin support (just select by color on the depth map, then blur), so it ended up rather crude. Unfortunately, I don't use Photoshop. Does anyone know if there's a standalone program or Gimp plugin that does the same?
R_Hatch ( ) posted Thu, 06 October 2005 at 1:57 AM
DOF Pro works in alot of other programs besides Photoshop. Go here for a list of the many free programs that can use Photoshop plugins.
odf ( ) posted Thu, 06 October 2005 at 2:22 AM
Well, I didn't know so many programs work with Photoshop plugins now. I guess I'll give it a try, then. The feature list seems really impressive, and I've been yearning for a decent way of adding DOF.
shedofjoy ( ) posted Thu, 06 October 2005 at 6:47 PM
bookmark
Getting old and still making "art" without soiling myself, now that's success.
