Tue, Feb 11, 12:56 AM CST
Subject: Wierd dark part
thewishmaster ( ) posted Sun, 09 October 2005 at 6:31 AM · edited Tue, 11 February 2025 at 12:53 AM
I have this dress I made for The Girl Next Door 2: Athletic
It have this wierd spot's but only in the cr2 I cant find them in the obj..! Is there any one that have any idea of what causes this ?
Rendergirls
svdl ( ) posted Sun, 09 October 2005 at 6:51 AM
Looks like a few polygons with inverted normals. You can fix them using the Grouping Tool: - create a new group; - select the offending polygons; - press Reverse Group Normals. Should work.
My gallery   My freestuff
thewishmaster ( ) posted Sun, 09 October 2005 at 7:09 AM
Yes I did also think that But no that isen't what's wrong...At least it do not fix the spots :( It's realye wierd..!
Rendergirls
thewishmaster ( ) posted Sun, 09 October 2005 at 7:16 AM
Mabye it's somthing with the grouping the spots is right beside the chest group and the right collar group ...!
Rendergirls
steveshanks ( ) posted Sun, 09 October 2005 at 7:34 AM
Can i get a look at the cr2 and Obj, be easier than trying to guess......its Steve@poserworld.com if you want to send it......Steve
thewishmaster ( ) posted Sun, 09 October 2005 at 7:44 AM
Thanks steveshanks I just send you a pm ..!
Rendergirls
steveshanks ( ) posted Sun, 09 October 2005 at 8:17 AM
Got it WM, your problem is lack of polygons, Poser doesn't have enough to create smoothness across the joint so you get the black marks, a sign of over smoothing, I doubled your polycount and then used UVmapper to weld vertices, it looks a lot better but would be better again if you could do the increase on a non cut up mesh then recut it.......Steve
thewishmaster ( ) posted Sun, 09 October 2005 at 8:32 AM
Oki Thanks I'll do that :) I've never figure this out my self..!
Rendergirls
