Default setting is 72 DPI. If you would like any other setting, go to "File/Render to Disk", you can change the setting there. Remember though, when rendering to disk, you are already "Saving As", so Do Not save the file again when your render is done, just close Bryce.
___
Ockham's razor- It's that simple
Bryce default dpi settings is 72. Anyhow if you want to change dpi and size of the render go to "filerender to disk". It'll allow you to do big renders with the desiderd dpi. Render to disk option renders without showing the progress in the wireframe space, it simply does all the render calculation saving directly to your HD. bye vasq
I was wondering how I go about setting up a render for 72 dpi please. I couldn't find it in my manual. thanks in advance Moonbow
