Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
There are quite a few free null figures around that would help you. There used to be some in Free Stuff here, run a search. I purchased a product from Shadownet et al. not long ago and it provided some technical information about this, I reproduce it here without their permission. Since I highly recommend their products, I hope they'll forgive me. Quote: "Cross-talk. This is when there is an internal master channel - often in the form of a Dial in one of the body part groups (such as a FBM) used on a figure to control one or more other dial/channels in the figure (and sometimes in other figures conformed to that figure, such as JCM in clothing. This is when crosstalk is good. When you load two of the same figures into your scene, and they have master Dials (or channels) exactly the same, only the first figure loaded will work correctly, and all other instances will be slaved to it - unless you load a NULL Figure in between the items you wish to separate. Not going to go into all that here as this information is widely known and available at any of the Poser forums. When this sort of thing happens, crosstalk is bad. " hope it helps. Luck Q
Un coup de dés jamais n'abolira le
hazard
S Mallarmé
Hi! (Sorry for my English) I have a problem with V3. If I put into a scene two o more vicky's figures,when I apply a morph from param dial(ex stretch legs) to figure A, the same morph is also applied to figure B !!. It is possible to fix that? Thank. Pierangelo
