Thu, Nov 14, 3:27 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: water transparency
palagas ( ) posted Fri, 14 October 2005 at 2:16 PM ยท edited Wed, 13 November 2024 at 6:50 AM
I need help with the water in Vue Infinite. I use the open ocean . and I am trying to make the water transparent enough to see fish swimming underneath. anyone know how to help me. all it says in the manual is to set the transparency to 100% for realistic looking water. Please help. Thanks
Veritas777 ( ) posted Fri, 14 October 2005 at 3:16 PM
You need to use the Vue Material Editor- which can be accessed by clicking on that material (water)- and then looking at Transparency tab- It will probably say its 100%. Most water in Vue is ALREADY set at 100%- so the problem can actually be making it LESS transparent (so that it renders faster... or reflects the sky better...
niandji ( ) posted Fri, 14 October 2005 at 7:42 PM
On the transparency tab, move the 'Fade out' setting towards clear, and/or lighten the fade out colour. Also adjust the 'Turn reflective with angle' setting depending on the position of your camera and the lighting.
