Fri, Jan 24, 12:33 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: HELP ME
helderres ( ) posted Fri, 14 October 2005 at 10:01 PM · edited Sat, 17 August 2024 at 3:57 AM
I acquired some archives of the Renderosity. I am using these archives in the DAZ3D but I am completely lost therefore I do not know as to install these archives in POSER 5. You can give an aid to me? Thank you (sorry my bad English It is a automatic translation) Hder helderres@uol.com.br
leather-guy ( ) posted Fri, 14 October 2005 at 10:16 PM
Help req -installing content into P5 for Non english member Better and faster assistance usually results if you put the problem in your subject line. A plaintive but meaningless header like HELP ME will sometimes cause old-timers to ignore a thread. A meaningful title will attract more focused attention and faster help. . . . hope one of those lines translates well.
Acadia ( ) posted Fri, 14 October 2005 at 10:28 PM
Attached Link: http://www.daz3d.com/support/faq/index.php?id=94
Character or a piece of clothing or shoes: - Found in libraries/character hair: - Found in either library/character/hair OR library/hair character texture addons, hair textures, clothing textures: - library/poses - Sometimes on the rare occasion, a merchant will package their textures so that they go into the "Camera" folder (.cm2 files). If that is the case then you can either apply them from there, or do what I do and change the file extension to .pz2 and put them in the Pose folder props: - Found in library/props Sometimes you will find clothing and hair or shoes in library/props too, depending on whether the item is actually created and saved as a figure, or it was created and saved as a prop. The link above shows you a picture of the structure which may help. When you install files, do this: Create a folder on your desktop Unzip the file there Look at it's contents and organize things the way you want them. If it's a Runtime folder, move it to your main runtime If it's just a bunch of files without a folder, then use the picture at that link to put them where they belong. Most things found here are already in Runtimes and go where they belong.
quixote ( ) posted Sat, 15 October 2005 at 12:56 AM
Here's a visual file management gif that used to be in the backroom here somewhere. This was for Poser 4. Hope it helps. Q
Un coup de dés jamais n'abolira le hazard
S Mallarmé
helderres ( ) posted Sat, 15 October 2005 at 8:40 AM
I am thankful to you very for the fast reply. I executed unziping os arquivos into the POSER directory. But I still having a problem. When I opened the POSER R, I sow some clothes located on menu figures, (not in props menu), and when I click on the each of them, this replace the human figure.
quixote ( ) posted Sat, 15 October 2005 at 11:52 AM
Clothes are not just props they can also be found in the "figures" folder. If they are conforming clothes, you must add them to the scene. You do that by first clicking on the clothing item in the menu and then clicking on the double check icon at the bottom of the menu.
After doing this don't forget to conform the clothing to the model. You might also want to take a look at the Poser 4 manual it does a good job of explaining all this.
S Mallarmé
helderres ( ) posted Sat, 15 October 2005 at 3:13 PM
Thank you! I Will Try now.
Acadia ( ) posted Sat, 15 October 2005 at 5:29 PM
Attached Link: http://trekkiegrrrl.dk/tut1.htm
Here is a really great tutorial to help you get a figure into the pose window, and put clothing and hair on it.
