Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Excellent dude! Be excellent to each other and Party On Dude! :)
No, I haven't been watching B&TEA.
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Attached Link: http://www.contentparadise.com/user/product.php?productid=13987&cat=1325&page=1
Link above: It's listed on the free stuff page BTW.Message edited on: 10/21/2005 12:25
Well Content Paradise seems to be a little bit down but it is under Free Stuff in the first row on the very right. May be the link worksMessage edited on: 10/21/2005 12:35
Ulli
I discovered that it makes a difference on whether or not you've bought Miki. I was logged in with my work CP ID (they finally bought me Poser6-Yeah!!!) and the link wasn't there. I couldn't add the freebie to my cart after using the direct link. So, I logged off and logged back in with my personal ID on which I'd purchased Miki. The item was there in my freebie section and now I have it, too. Thank you!
Its in red on the product description but its pretty hard to read, I'll suggest someone change that. ------------------ *If you purchased Miki directly from Content Paradise you are prequalified. *If You purchased Miki in a retail location you will be required to enter your the serial Number found inside of the Miki box. *If You purchased Miki from any of the e frontier stores or affiliates you will be required to enter your online order number such as a Digital River or Element 5 order number. ------------------ So if you bought from the e frontier (Digital River) store, you use your order number. -Rylan
The item show up now under the other sign in (I know it wasn't there a little while ago because the red plant for Shade moved over in the line). I spoke too soon about getting the item. When I click to check out I get an error that it failed to connect with the WWW but it is not a firewall error message. I even tried adding an item to purchase that's not free with the same results. I just now was able to complete the transaction so it was probably a glitch.
Krazik, would you mind waving your wand again? I'm getting the exact same error as mylemonblue :o(
Ulli
