Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Attached Link: www.andromeda.com/
Andromeda has some nice ones I use for this. Click the 'screens' and 'cutline' filter, but they are from $74 to $109.Attached Link: http://www.renderosity.com/viewed.ez?galleryid=534055
Ooh! That's a plug-in I'd like to have. 'Twould make my life easier. In the meantime, joezabel, there are also ways you can achieve acceptable results using the regular Photoshop filters -- that is, if you're in a rush and can't get the filter right away. The thing is, you have to do it in parts and pieces. The attached link is one of my older images converted to line art using just the standard Photoshop filters in 6.0. The original image can be found here: http://art.aprilgem.com/poser/poser14.html Anyway, I did it in parts and pieces -- I had several copies of the image on separate layers. I posterized some of the layers so that the color gradients were less smooth and broken up into blocks, and THEN I used the sketch/graphic pen filter on them. I used different settings and the multiplied the layers so they all added up. I can't quite remember the exact steps I made, but it's always a trial and error with each image anyway -- you get different results with different color schemes, and sometimes the technique works well while other times it doesn't. That's in if you don't have the Andromeda filter and you're in a bind, though."Is that picture using a standard PS filter?" Which picture do you mean? If you mean the one I linked to, yes, it is, in passes. There was a point in my life where I took pride in using nothing but Photoshop's standard filters to achieve effects (mostly because I didn't have any plug-ins). The graphic pen filter was used several times, sometimes with the option of slanting right and other times with the option of slanting left. I think I also used the find outlines filter and desaturated the result. This is all after using the posterize feature. These passes were done to different copies of the image on separate layers, and the layers were set to multiply. After everything I did, I made sure to flatten the image, convert everything to grayscale, then to bitmap mode. Worked like a charm.
Attached Link: http://www.swsoftware.com
This one uses artist effects like brushes to create the final output. They also have a trial version available for try out.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
