Sun, Jan 19, 10:10 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 19 8:40 am)
Subject: HAir MAT and Poses/problem with renders
seduced2cheat ( ) posted Sun, 23 October 2005 at 11:13 AM · edited Fri, 02 August 2024 at 8:12 AM
Hi all, Here is a 2 part question: 1. I have poser 6 and have some new hair models, some from Daz and some from Content Paradise. They are all showing MAT poses and Style poses in Poser, but when I click on them, nothing happens. The Daz hair I installed normally, the CP hair I extracted to the Poser 6 folder. There must be something off here but I did not know how to fix it or whether it is a general POser 6 issue. 2. When I use texture filtering in Firefly, I am sometimes getting white creases on the texture maps. When I take texture filtering off, I get ratty looking hair. Is this a catch 22, or something I can fix in Render Settings? Any Help is appreciated. S2C
PabloS ( ) posted Sun, 23 October 2005 at 11:56 AM
Hi seduced! #2 is a well-known problem. Remove texture filtering and add a slight bit of displacement, e.g., .0001 on the hair (if I recall correctly...seems there was another solution as well). As for #1, I have no idea. What hair is it?
Tyger_purr ( ) posted Sun, 23 October 2005 at 4:29 PM
#2 the "other" solution. select the hair and go to the properties and change the shade rate to something small like .02 then change the shade rate in the render settings to match.
My Homepage - Free stuff and Galleries
spiritwolf2000 ( ) posted Mon, 24 October 2005 at 1:12 PM
Ive run into #1 here lately. When using Aliz Hair (HR file).
seduced2cheat ( ) posted Mon, 24 October 2005 at 8:08 PM
Thanks on 2. The hair models were Agent hair and Lush HAir from Daz.
