Wed, Dec 25, 8:25 AM CST
Subject: Image application
vanezz2 ( ) posted Wed, 26 October 2005 at 4:46 AM · edited Wed, 25 December 2024 at 8:07 AM
I will try asking this question once more. How do I apply a .jpeg image to a prop such as a cube surface in Poser6? Thanks for any help.
mrsparky ( ) posted Wed, 26 October 2005 at 5:28 AM
"How do I apply a .jpeg image to a prop such as a cube surface in Poser6?" You use the material room. See screensots on this post. But remember if you want to add a picture to the whole cube, say for example turning it into a crate or cardboard box. You need to map the prop/figure using software like UV-mapper or lith unwrap.
mrsparky ( ) posted Wed, 26 October 2005 at 5:29 AM
mrsparky ( ) posted Wed, 26 October 2005 at 5:30 AM
mrsparky ( ) posted Wed, 26 October 2005 at 5:33 AM · edited Wed, 26 October 2005 at 5:33 AM
in stage SEVEN just remember your filename will be different.
Message edited on: 10/26/2005 05:33
vanezz2 ( ) posted Wed, 26 October 2005 at 7:59 AM
Thanks a lot. I just could not find the Image Map application. I have it all under control now. Cheers Ray Van Sickler
diolma ( ) posted Wed, 26 October 2005 at 3:33 PM
"But remember if you want to add a picture to the whole cube, say for example turning it into a crate or cardboard box. You need to map the prop/figure using software like UV-mapper or lith unwrap." Ummm... yes, but you don't need to for something as simple as a box. You can do it in Poser via the grouping tool... 1. Select the box. 2. Change display mode to "Hidden Line". 3. Click the grouping tool. 4. Click "New Group". Give it a name (front, back, etc.) 5. Select the polys of a surface (then rotate around to be sure you haven't included any polys you didn't want...) 6. Click "Assign Material" (near the bottom, under Geometry Functions"). Repeat steps 4-6 for each of the surfaces (with different names of course). Exit group tool, go into mat room, apply different images to each surface..:-)) Cheers, Diolma
diolma ( ) posted Wed, 26 October 2005 at 3:50 PM
(Got back here to late to edit original post).. If you already knew all that I apologise for wasting your time. OTOH, somebody else might gain knowledge:-)) Cheers, Diolma
