Sun, Feb 9, 9:34 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Figure Number in PoserPython?
Cage ( ) posted Fri, 28 October 2005 at 1:34 AM · edited Sun, 09 February 2025 at 9:20 PM
I'm trying to develop a method to correctly apply JCM pointer poses using Python. This requires that I be able to determine the internal figure number for the parent/target figure. But PoserPython doesn't seem to have any tool to query the figure numbers. I thought I could work around it by assigning a new figure name, but I can't seem to locate anything that will do that, either.... Does anyone know any secret methods or tricky workarounds that might help me with this? I need to find the internal figure number, by which I mean the numbering applied internally to figures in the order in which they load in Poser. example: Figure 1 BODY:1
mkrueger ( ) posted Fri, 28 October 2005 at 12:11 PM
Hi!
Try this:
  • get the actors list for the current figure:
actors = poser.Scene().CurrentFigure().Actors()
  • loop through the actors and get the first one which is a body part with the "IsBodyPart" method
  • the internal name of the actor should be PartName:FigureNumber
so you should be able to extract the figure number after the colon
hope that helps
martin
Cage ( ) posted Fri, 28 October 2005 at 2:36 PM
That's a great idea! I was not aware that the number was addended to the internal body part names like that. I'll try it. Thank you!
Cage ( ) posted Fri, 28 October 2005 at 2:54 PM · edited Fri, 28 October 2005 at 2:56 PM
There's a complication with the suggested approach. I can't make any comparative statements to determine what number is addended to a body part, because PoserPython returns values in computerese. :) It's internal way or thining about things doesn't seem to resemble any of the ways it annotates those thoughts. (Kind of reminds me of myself, that way....)
So, fool that I am, I'm stuck. Now I need to ask if there is a way to convert this list of Actor objects to a list of body parts that can be read. I assume that's some kind of value to string conversion, but I'm not sure these listed parts count as integer values, so I have no idea how to approach the matter....
Am I missing an obvious approach?
Code:
#Find internal figure number----(Thanks, mkrueger!)---------------------------
print actors
Result:
[, , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , ] Well, the list doesn't show up in the post, so I'm addending a text file to the next response....
Message edited on: 10/28/2005 14:56
Cage ( ) posted Fri, 28 October 2005 at 2:57 PM
Here's the resulting list of actors.
mkrueger ( ) posted Fri, 28 October 2005 at 5:18 PM
Hi! What you get is a list of Actor objects. So you have to call the method "InternalName()" for each of this object to retrieve the actual string. I appended a short code fragment that extracts the number. martin
Cage ( ) posted Sat, 29 October 2005 at 1:37 AM
D'Oh! I just spent all afternoon creating a "counter" method which would keep track of the figure numbers for me. It looks like this will be much simpler. Life's kind of a bummer when you're always just smart enough to keep doing things the hard way.... :) Thank you! Hopefully I'll fare better with this example than I did with the last one. Underestimating me is overestimating me, it seems. :)
Cage ( ) posted Sun, 30 October 2005 at 1:12 AM
"Addend" is not a verb. Thank you to an anonymous guardian of the whaddaycall vocabu-mo-lary. Note to others: Don't be like me!
