Wed, Dec 25, 12:28 PM CST
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
Subject: Exposure Effect?
Larry-L ( ) posted Fri, 28 October 2005 at 7:41 AM · edited Wed, 25 December 2024 at 12:28 PM
Greetings, I am a beginner in photography and interested in learning new techniques. One of which is how to set an exposure for moving water as shown in this recent posting by: mezmerizeme http://www.renderosity.com/viewed.ez?galleryid=1078016&Start=55&Sectionid=0&filter_genre_id=0&WhatsNew=Yes. I have seen this technique used several times and would like to experiment with it myself. Would you all be so kind to explain exposure settings for this kind of shot? Thank you in advance, Larry-L
Onslow ( ) posted Fri, 28 October 2005 at 8:42 AM
Hi Larry, I'll try explain a little 'cos I'm here but perhaps one of the others who takes these will be able to do a better job. The type of shot you are after takes a long shutter speed so the water moves during the time the shutter is open. This is usually achieved by stopping down the aperture to it's smallest setting and using a neutral density filter or maybe a polarising filter to cut down on the amount of light entering the camera. You would need to keep the camera abosolutely still during the exposure so the background is sharp so a tripod will be necessary too. What type of camera do you have? Richard.
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies live;
Their heads are green, and their hands are blue, And they went to sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
Larry-L ( ) posted Fri, 28 October 2005 at 8:53 AM
Thanks for the reply. I have a Canon Digital Rebel XT and I bought a 12-24 wide angle lens and a macro lens along with a standard 28-105 lens.
Onslow ( ) posted Fri, 28 October 2005 at 9:08 AM · edited Fri, 28 October 2005 at 9:10 AM
So if you used F22 @ 28mm you could focus to about 4ft and have everything in focus to infinity plus it would give you fairly long shutter speed if the light wasn't to bright, otherwise you will need to use a filter to get a longer shutter speed. The shot is best taken on overcast days usually to reduce the contrast a bit to get a good tonal range.
Message edited on: 10/28/2005 09:10
Edward Lear
DJB ( ) posted Fri, 28 October 2005 at 9:25 AM
Good thread.. I been asking in comments on the images I see like that to post thier shooting data. This is something I want to try too.
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
Jack Casement ( ) posted Fri, 28 October 2005 at 11:44 AM
Speaking of shutter speeds, can anyone guess what speed this was taken at. I will give you a hint. It was hand-help no tripod. I will come back with the answer later after you have had a guess
Larry-L ( ) posted Fri, 28 October 2005 at 6:39 PM
Thanks for the replys. Sorry Jack, being the author of this thread therefore the beginner I wouldn't know where to start a guess.
tibet2004uk ( ) posted Fri, 28 October 2005 at 6:50 PM
I think Rich explained it perfectly well Larry! Good luck with that and don't forget to post ur attempts in the forum to have more feedback! ;)
soulofharmony ( ) posted Sat, 29 October 2005 at 4:06 AM
First of all how l would approach some thing like the waterfall or..mezmerizeme water movement is the following.. Take my first shot in automatic this gives me correct exposure and by checking the info l can see the shutter speed and iris setting and iso that the camera has set. Then in manual l can slow the shutter speed down by two stops and close the iris setting by two stops, this gives the same over all exposure.. l can then review that shot on replay..and see the effect on the water. what ever you do on the shutter speed.. you do the opposite on the iris.. one my swan shot managed to freeze the water at shutter speed 1/400 f 7.1 iso 200.... use that as a guideline is you like.. @jack... would say a really good fluke shot on automatic its gorgeous..:)))))
I Discovered the secret of the sea in mediation upon the dewdrop ... Sand and Foam Gibran
<a href="http://www.soulofharmonyphotographics.org/">Visit My Website</a>
soulofharmony ( ) posted Sat, 29 October 2005 at 4:26 AM
Larry carry with you a note book and pen, take shots on your automatic default .. read the info. write them down..then when approaching the subject , you can work around the settings...it takes time.. anytime you need advise.. your welcome..:)..:))) Nikki
Larry-L ( ) posted Sat, 29 October 2005 at 9:20 AM
Thanks for your instructions. Once I get some time I will try these out.
Radlafx ( ) posted Sun, 30 October 2005 at 12:22 PM
Speed is 1/69
Question the question. Answer the question. Question the answer...
I wish I knew what I was gonna say :oP
Jack Casement ( ) posted Sun, 30 October 2005 at 12:52 PM
Attached Link: Original Waterfall shot
In answer to the question I posed a couple of days ago about what speed was used on my waterfall shot. Well, believe it or not it was taken at 1/250th at f8. The "movement" in the water was created in Photoshop using the Smudge Tool. It's easy. Try it.
PS. This is the original shot.
soulofharmony ( ) posted Sun, 30 October 2005 at 2:06 PM
smudge tool on pshop..sacrilege.. Its a gorgeous composition...jack..:)..:))))))
soulofharmony ( ) posted Sun, 30 October 2005 at 2:12 PM
p.s truly fantastic website jack.. love the monochromes.. old man of kashmir.... lovely galleries :)
Jack Casement ( ) posted Sun, 30 October 2005 at 2:15 PM
Soulofharmony Many thanks for your kind and generous comments. I have always had a weekness for monochrome. Cheers
