Photography F.A.Q (Last Updated: 2024 Dec 31 10:42 am)
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1077989
imageMessage edited on: 10/28/2005 21:36
"The happiness of a man in this life does not consist in the
absence but in the mastery of his passions."
beautiful entry.. excellent...:)..)))) so detailed
I Discovered the secret of the sea in mediation upon the dewdrop ... Sand and Foam Gibran
<a href="http://www.soulofharmonyphotographics.org/">Visit My Website</a>
Attached Link: Tutorial
Sorry Lou I deleted that last one you out in, as it goes to a microsoft site. If you copy and paste the URL of you image as you did...you will get 2 http// 's in that section. You see, it is already in that space provided. The way to correctly do it is to backspace out the other http and then paste yours in. You should leave off the information after the number on your address. For instance... http://www.renderosity.com/viewed.ez?galleryid=1077989 takes you to your gallery image.This is all that is required to send people there. You can also type in the name of the image where it says Caption. See the above link for a better tutorial."The happiness of a man in this life does not consist in the
