Sat, Jan 11, 9:28 AM CST
Subject: Image Sequence
tony3d ( ) posted Mon, 31 October 2005 at 7:42 AM ยท edited Thu, 09 January 2025 at 12:43 PM
Is there a way to set a frame at which an image an sequence will start to run, or will it always start running on the first frame of the animation?
ablc ( ) posted Tue, 01 November 2005 at 2:01 AM
i think u should just load the first image u want your anim to start.
thundering1 ( ) posted Tue, 01 November 2005 at 7:54 AM
Do you mean choose when "the camera starts to move" or when "the animation will start"?
tony3d ( ) posted Tue, 01 November 2005 at 9:54 AM
When the image sequence animation starts. In Lightwave you can just tell the sequence which frame to start running on simple as that.
thundering1 ( ) posted Tue, 01 November 2005 at 10:14 AM
At least for the simple animations (with the Animation Wizard at least - haven't dived too deeply into the editors yet), the frame you're looking at in your Camera View is going to be your starting point. And then it just goes forward (or whatever direction you want) from there. But in the editor you can set that the animation will begin (say, wind blowing trees and grass, cars moving forward, etc.) so things start happenening, and then you can set keyframes for the CAMERA to start moving around in the scene.
