Fri, Feb 7, 8:00 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: Is it possible to start a BVH file on frame 60?
beos53 ( ) posted Thu, 03 November 2005 at 12:30 AM · edited Fri, 07 February 2025 at 7:53 AM
Is is possible to start a BVH file to (or even move a the start of a BVH file to a differant frame like frame 60. The first 60 frames be the movement I put in then it would continue on with the movement from the BVH file.
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia GeForce GTX 750 Ti
HAWK999 ( ) posted Thu, 03 November 2005 at 2:37 AM
Yes, just put your time marker at frame 60 and import your bvh.
wolf359 ( ) posted Thu, 03 November 2005 at 3:58 AM
However the default location of the figure will likely shift dramaticly when the BVH is applied.
My website
ockham ( ) posted Thu, 03 November 2005 at 9:37 AM
Attached Link: http://ockhamsbungalow.nstemp.com/Python/BVHmixer3.zip
You could also try my BVH importer script, which applies the motions in a 'non-absolute' way....
My python page
My ShareCG freebies
beos53 ( ) posted Thu, 03 November 2005 at 5:58 PM
Thank you for the information This is going to help me out a lot ockham what do you mean by "applies the motions in a 'non-absolute" way..."
imagination304 ( ) posted Tue, 07 August 2012 at 11:00 PM
(bookmarked)
masha ( ) posted Wed, 08 August 2012 at 1:38 AM
Ockham, I get a 404 on that link Thanks.
imagination304 ( ) posted Wed, 08 August 2012 at 9:00 AM
http://ockhamsbungalow.com/Python
masha ( ) posted Wed, 08 August 2012 at 8:06 PM
That worked thanks.  A veritable treasure trove of scripts to help with repetitous or painful tasks.  Great help for animators Since they are py extentions they should work in the latest versions of Poser as well I presume.  Grab these.
jerr3d ( ) posted Thu, 09 August 2012 at 3:33 AM
Usually if I import a BVH into the middle, I change the camera angle and make it a separate shot.  Just easier that way. ^ ^;
