Thu, Dec 12, 12:02 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 3:30 am)
Subject: Two questions on Poser 6
szymas ( ) posted Thu, 03 November 2005 at 11:32 AM ยท edited Wed, 04 December 2024 at 3:21 PM
Ok, Poser six's a little different then 5, I would like to know how to clear the renders in the "Render Tab" and also from the drop down list below (is it eating disk space, memory?) also, what is the "best" firefly setting for final production, no, not sliding the tabs all the way to the right ;) Thanks..
Jules53757 ( ) posted Thu, 03 November 2005 at 4:12 PM
The number of cached renders you can change under edit/general preferences. It will save you a little bit of disk space. The "best" settings are the ones YOU like most means you find the results OK
Ulli
diolma ( ) posted Thu, 03 November 2005 at 4:27 PM
"what is the "best" firefly setting for final production, no, not sliding the tabs all the way to the right?" As Jules said: "The "best" settings are the ones YOU like most means you find the results OK". Use the MANUAL settings to get what you want. When you find a good one, save it via "Save Preset". You can save several, for different circumstances, then reload them via, (ahem) "Load Preset"...:-) Cheers, Diolma
