Sun, Feb 2, 11:55 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Fire looping
noviski ( ) posted Sun, 06 November 2005 at 6:50 AM · edited Sun, 02 February 2025 at 11:55 PM
Hi, Im trying to make a torch movie using the fire tool and I cant make a loop. How can I set the loop for a 2 seconds clip with 30 fps? Thanks!
ominousplay ( ) posted Sun, 06 November 2005 at 7:00 PM
Are you trying to make the annimation loop? You could adjust the flame height, width, etc. as an annimation, then look that - plus you are probably changing texture properties. Highlight your key frames and repeat them as many times as needed.
Never Give Up!
Nicholas86 ( ) posted Mon, 07 November 2005 at 12:01 AM
It will not loop. I'd suggest either a movie with a alpha map. Or Primivol.
noviski ( ) posted Mon, 07 November 2005 at 12:21 PM
Thank you, guys. I solve the problem with a bilboard primitive with a fire shader. Im not sure, but this fire primitive works fine in RDS. Thanks for the help!
