Mon, Feb 10, 1:59 AM CST
Subject: WIP cave island ... one more try.
EricofSD ( ) posted Wed, 07 March 2001 at 9:18 PM · edited Wed, 05 February 2025 at 12:54 PM
Attached Link: http://www.annsartgallery.com
Had a tough time uploading this for some reason. Anyway, could use some feedback. thanks.
Kemal ( ) posted Wed, 07 March 2001 at 10:26 PM
Hmmmmm.... Water looks good , but a hole in Your whatever You call it is shaped unnaturally which is telling me that You used cylinder to make it! Try to use another terrain or something...(just don't forget to make it solid!). It's maybe too early for more comments, hope mine will help You !!!
flaxcrack ( ) posted Thu, 08 March 2001 at 11:24 AM
Attached Link: http://peepee-weewee.hypermart.net/tiffy/
Yeah, I think a different terain would be nice. You might want to use the editor button to add some filters to the cylinder you made to make it look... ummm.. A little more oblique... But you need something in the foreground though... Its all a back ground pictuer.... Kemal, be nice dude...
Deathbringer ( ) posted Thu, 08 March 2001 at 12:34 PM
It may fix itself when you use the different terrain, but it appears to me that the hole is also tilted towards the back, which would make it hard for water to run out. Other then that looks good. Keep up the good work.
EricofSD ( ) posted Thu, 08 March 2001 at 10:49 PM
Thanks, I hate the hole. Its a rock but yeah, it does look unnatural. Ok, the idea to shift it sidways is good. I think there needs to be more terrain to generate that kind of water. As for different terrain, ok, I'll play. What did you have in mind? Sedimentary rock? More plants? thanks for your help. Also, there's a distortion at the top of the waterfall that I had not anticipated. Don't know if I like it. Maybe its ok.
flaxcrack ( ) posted Fri, 09 March 2001 at 8:47 AM
Ok, make the mountain huge, and make it not stone but something like the rock/wood deal or something like that. And then have the camera raise up so you see the lake of the waterfall and the waterfall starting to flow over the rock. After doing that add some plants to where it spews over the rock. That would look good and put some ducks or elfs takeing baths in there or something to take away just from there being a waterfall. Ya know what I mean? Flaxcrack
Kemal ( ) posted Sat, 10 March 2001 at 3:05 AM
Actually,I was suggesting using to different terrains ,one positive, other negative. Making the union of these 2 objects , hole looks more natural...
