Photography F.A.Q (Last Updated: 2025 Jan 30 8:47 am)
What I am seeing is not 'lens flare' it is 'fringing' - as doug has said it is caused by overexposure at that point. It occurs when there is an over exposed area next to a darker area in an image eg. shooting a tree against a bright sky you can often get a purple/blue fringe around the branches. It occurs most when there is a wide difference in the brightness and the exposure of the bright area is clipped by more than one stop. Most likely cause is voltage or light leak/bleed between individual sensor sites but manufacturers have spent a lot of money researching this and amending algorithms, sensor design to try and resolve the problem with so far only limited success. Difficult to do much about in this situation except to change the lighting.
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies
live;
Their heads are green, and their hands are blue, And they went to
sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
Ahhh ok - I see it now. I missed that thinking it to be part of the planes paintwork.
live;
sea in a Sieve.
Edward Lear
Flares are caused by the reflection of bright things in your lens system. Whether that be an actual light source or the reflection of a bright object doesn't really matter. In effect the landing gear here is a light since the reflection of the light there illuminates part of the plane.
What is a friend? A single soul dwelling in two bodies. -
Aristotle
Glass Eye Photography =- -= My Rendo Gallery =-
Message edited on: 11/09/2005 23:10
