Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 6:38 am)
Quoting the SR2 readme: 1) "There is an incompatiblity with Unsanity's Window Shade X. Some fixes in SR2 that solve window layering problems under Mac OS X Tiger can cause an undesired Window Shade effect on Poser palettes. Please add Poser to Window Shade X' list of excluded applications if you encounter this problem."
Message edited on: 11/13/2005 10:59
Doh! Thanks, stewer. Totally forgot I had any windowing utilities installed that could be conflicting. Issue 1 is now gone. I won't know about the "Build Folder Menu" issue until it happens again. Selecting that option did nothing at all for me - no dialog box, no folder menu, nothing. Perhaps because of the Window Shade X issue...
For now, SR2 has broken more than it has fixed for me. I'm running on a 17" PowerBook with OS X 10.3.9.
When switching between applications, the main Poser window and the Parameter Dials window go away - only their title bars remain. So far, the only thing I've found which brings back the Parameter Dials window is repeated switching between applications using the dock. This appears to happen every time P6 is sent to the back or hidden.
On two occasions in the last two days, the tools window has lost the drop down menu for my runtime. In its place is a menu which says something such as "rebuild menu" and "add category". The rebuild selection does not seem to work. The only thing which seems to bring the menu back is to switch runtimes and then return to my main runtime. This is really aggravating because my main runtime is quite large and takes some time to load.
Anyone else seeing this nonsense?
