Thu, Nov 14, 1:18 PM CST
Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
Subject: Need help importing Poser objects into Bryce
strife180 ( ) posted Thu, 08 March 2001 at 11:25 PM · edited Thu, 14 November 2024 at 3:58 AM
Im a newbie when it comes to bryce 4 and am currently having problems when i import objects in to bryce 4 from poser 4. It carries none of the textures or detail mappings. Please help!
flaxcrack ( ) posted Fri, 09 March 2001 at 8:42 AM
Attached Link: http://peepee-weewee.hypermart.net/tiffy/
Strife, Hey man, if Bryce is not doing if for you then something is wrong with the software and you need to reinstall. But if you are running a version less than 4.0.2 then you need to check out www.petersharpe.com and check out the tutorials and in there you will find out how to add the textures. Good luck man... Post, us your image when your done with it.. :-) Flaxcrack
Skygirl ( ) posted Fri, 09 March 2001 at 3:04 PM
Hi Strife ! Save your Poser 4 file as an obj file. Load Bryce and import the file into Bryce. Your texture should be ok that way. If not load the texture into Bryce and then texture your obj file as you would texture any other object in Bryce. Both methodes works fine by me and Im running a plain Poser 4. My Bryce is version 4.0.1. Try it or write here again, ok !?! Sky G :-)
DigitalArtist ( ) posted Fri, 09 March 2001 at 10:57 PM
Attached Link: http://www.brycetech.com/tutor/bryce/posertobryce.html
Heres a link to a well documented tutorial that I've found very useful. Best Regards, -Matt
