Thu, Feb 20, 1:48 PM CST
Forum Moderators: RedPhantom
Subject: recent update patch wierdness
MacXimus ( ) posted Fri, 09 March 2001 at 8:35 PM ยท edited Thu, 20 February 2025 at 1:47 PM
When I loaded the 4.0.3 patch it duplicated a lot of file folders under "Poser4 Updater Save". This folder looks to have a lot of updated material in it. It also has an executable file called PoserSave.exe. When I tried to activate it it gave me an error message: missing imageioutilities.dll. The patch site did specify some passible .dll problems associated with this patch. But the .dll I am missing is not one of them. So I tried to go to the .dll archive on their link... No dice, the whole archive is missing. Poser seems to run fine if I launch it from the normal .exe Any clues?
wyrwulf ( ) posted Fri, 09 March 2001 at 10:37 PM
The files in the folder you refer to are the backup of the ones replaced by the update. The PoserSave.exe is probably supposed to put them back. I just deleted the Updater Save folder when I ran the update. You might want to contact Curious Labs about it before you do the same.
thgeisel ( ) posted Sat, 10 March 2001 at 3:55 AM
wyrwulf is right.its a backup of your old files.If everything works fine after the update, you can delete it. otherwise you can replace the new files manually or by uninstalling the update
MacXimus ( ) posted Sat, 10 March 2001 at 6:20 AM
thanks much
