Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:08 am)
Well, I can answer that one (see above..) (You have to click on the "Camera Controls" to get the drop-down menu, then select the "Shadow Lite" (or "Shadow Cam") that you want. Be warned: - if you change your lights, the shadow cam names may not match the lights names... Also, (as you can see) the last cam you selected can also remain checked (in this case "main")... But it usually works....
Cheers,
Diolma
Message edited on: 11/17/2005 16:45
2. SR2 seems awful slow updating the screen when I select different figures/body parts. Sometimes clicking on a body part doesn't work at all. Will a faster/newer video card help this?
Maybe. Simply updating your current card's drivers (if they aren't the latest) might help, also. I haven't experienced any slowdowns like that, myself.
Have you tried switching to the SreeD software-only display instead of using OpenGL?
Thanks, Diolma, it works!
LD: I do have the "latest" drivers, but my card is so old the latest drivers are too. Your tip worked, though. It does seem a tad faster now. Thanks!
Jules: I'm happy for you :)
No one knows the answer to number four?
Message edited on: 11/18/2005 15:52
Is there a way to view through a shadow cam? If so, how?
Is anyone else having trouble with DAZ Dial Cleaner deleting all a figure's body morphs? Is there a way around it?
Trivia question: Quick, without looking...what is the very last body part for a human character in the drop-down list (not counting Jessie, James or Apollo Max)?
Thanks in advance.
Message edited on: 11/17/2005 16:12
