Errm -- actually that won't work.. Poser saves the cloth out unchanged; the changes are applied via the .dyn(?) file, which you can find in the same folder as where you saved the file.. Your best bet for a single-frame pic is to either export the cloth as a .obj (although that might mean you have to re-apply some textures) or spawn a morph target for the clothing and apply it to the original cloth. Save in library. Save you character's pose too. It's proabably best to exit & re-start Poser at this point (to free up memory), and re-load you scene. Set # frames to 1 (when Poser asks if you want to delete frames, say Yes). Apply Pose to figure, either load the saved .obj or load the cloth with the morph in it from the library (and, of course, apply the morph). Save file (under DIFFERENT name!) and then use that in Vue... Hope that helps, Cheers, Diolma
Martial, what settings did you use, both when saving and re-loading the cloth?
When saving, turn all options off except for "include existing groups" (in order to retain as much of the mat room info as possible). When loading, turn ALL options OFF.
There should be absolutely no difference between the two meshes...
Cheers,
Diolma
PS: Which version of Poser are you using? (It can sometimes make a difference..)
Edited to add: if you left "100% of figure size" checked, that would explain it - what that does is scale the import up or down to the "standard Poser figure" size..
Message edited on: 11/20/2005 14:47
Bonjour.I use Poser for a long time but always for still image.I begin to use dynamic clothing recently.I have a 30 frames scene.The dynamic cloth is at the right position at the frame 30...but at the frame one (1) all is at zero setting position.I just want keep the last one ,the frame 30 ,and delete all others frames.In the animation palette .the icone with delete key frame seems not work.The problem is when i import the poser file in Vue 5 infinite.the import file arrives with frame 1 and all at zero setting position.i have try to save all the figure at the frame 30 in figure librarie but when i call back the file the dynamic cloth is not there.So How to keep only the frame 30 where all items is ok?thanks
