Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Aiko and Hiro are Anime characters. Sheesh, everybody knows that Anime characters don't have genitalia! .... Well, except for the Hentai/Yaoi stuff. ;0) [Key 'Mission Impossible' music] It is your mission, if you decide to take it, to remedy this deficiency. Message will self-destruct in five... [BOOM!]
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Hiro can use David's genitals, more or less. They don't fit quite right, but you can get them to fit if you work at it. Of course, almost no texture made specifically for Hiro will have a genital map, but I think a couple include a map for David's genitals (or you can just use a David texture). Arduino has made a set of genitals for Aiko, similar to those he's made for other characters. I'd say check at Renderotica to purchase said genitalia. I haven't had the need to use Hiro naked so it hasn't been an issue, but it's fairly easy to postwork appropriate genitals on Aiko (and yes, I have ;-). bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
I started to make some morphs for Aiko, not really finished until now as I worked more on my favorite figure MIKI. The morphs are not perfect but I think I can give you a link to them. They are not officially placed on my Homepage but you can download them if you follow this Link. They are in .obj format so you have to load them manually.
Have fun
Ulli
You don't need a prop for Aiko as the pubic hair is in the mesh. You can use my morph or the one made by Arduino, to bring it out. If you want it very realistic, look for Perfect G at Arduino.net. Even Tiziana for V3 works with Aiko LE, the only thing, you have to add some morph channels via Morphmanager. For the Pubic hair you can use any V3 Transmap with Pubic hair or a V3 Texture with that. Also if you look, you can easyly change the shape of the PH with my morphs, just for fun.
Ulli
why was aiko and hiro not made with genitals? did I miss something? are they hidden somewhere? why? I adore aiko she is wonderful to use. so very little post work on her joints....but she is not"fully" anatomically correct..and hiro..poor hiro.....
https://www.darkelegance.co.uk/
Commission Closed till 2025
