Sat, Jan 25, 1:49 PM CST
Subject: Is it just me? SR2 morph problem
guarie ( ) posted Wed, 23 November 2005 at 8:17 PM · edited Fri, 10 January 2025 at 11:00 PM
I was playing with V3 in Poser 6 and discovered a problem since upgrading to SR2. The morphs are not working the way they should. There's a render below showing BreastSize 3 on V3 in P4, P5 and P6 and while P4 and P5 reduces the breasts, P6 increases them. Its almost like its reversing the dial settings. ie 1 is now -1 and -1 is now 1 I should also add that BreastSize3 was the first I discovered. Its also not working on others as well. It also seems to be distorting magnets as well. I'll do a render to show later. Has anyone else discovered this? Or am I just losing the plot?
PabloS ( ) posted Wed, 23 November 2005 at 9:00 PM
I hadn't noticed it, but I'm sure interested in what you find.
elizabyte ( ) posted Wed, 23 November 2005 at 9:56 PM
And filmed it for a reality show!
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
kuroyume0161 ( ) posted Wed, 23 November 2005 at 10:43 PM
I just tried it between Poser5 and Poser6 (6.0.2.118) and exactly the same between.
 -- Bjarne Stroustrup
guarie ( ) posted Wed, 23 November 2005 at 10:50 PM
Exactly the same as I found or the morphs worked the way they should in P6? I'm using Poser 6 (6.0.2.118) as well on a PC.
kuroyume0161 ( ) posted Wed, 23 November 2005 at 11:02 PM
The breasties shrunk in both instances... :) This could be a faulty SR2 install. I'd direct the problem to e-Frontier (at least there's no Turkey-Day in Japan - Sushi-Day would be nice, though).
tastiger ( ) posted Wed, 23 November 2005 at 11:27 PM
I can confirm that as well - just mucking around here and the settings seem reversed...
The supreme irony of life is that hardly anyone gets out of it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz   3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
