Sun, Feb 16, 11:33 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Subject: Saving groups of props together
solofalcon459 ( ) posted Fri, 25 November 2005 at 1:01 PM · edited Tue, 04 February 2025 at 4:06 PM
I've got these prop spikes and am trying to save them as a group and then be able to load them back in and have them appear in the correct place at the end of the fingers. I aligned them with each finger and then parented them to each finger. I selected the thumb spike and hit the + to save them in the prop library. It asks for a name and I did that, then hit subset and selected each spike. It doesn't ask me about making a smart prop after that. When I load the prop, they appear below the hand, not aligned. What do I need to do to get them to load properly??
ockham ( ) posted Fri, 25 November 2005 at 1:21 PM · edited Fri, 25 November 2005 at 1:24 PM
Poser can only save one thing at a time as a
smart prop. There is a way to do this, but
you'll have to edit the PP2 file so it contains
a 'package' of all the props.
For each claw:
Select the claw.
Hit the plus sign to save prop.
Do not click Subset.
When Poser asks if you want to save smart, say Yes.
You'll then have 5 separate smart prop files,
one for each claw.
Then take all 5 of the pp2 files and throw them
together. Copy and paste each one after the
previous into one big pp2.
Then the critical part:
At the bottom, find the doc section.
It will look like this
doc {
addActor claw:3
Make it look like this, so that it includes
all 5 claws in the 'package':
doc
addActor claw:1
addActor claw:2
addActor claw:3
addActor claw:4
addActor claw:5
Then go back into the upper part and
revise the internal names for each claw
so that the thumb is claw:1, the first
finger is claw:2, and so on.
The lines to change are the ones starting
with 'prop':
prop claw:3
Finally, remove the 4 upper doc sections, leaving only the one you've
assembled at the bottom of the file.
Message edited on: 11/25/2005 13:24
My python page
My ShareCG freebies
solofalcon459 ( ) posted Fri, 25 November 2005 at 1:50 PM
Wow, thanks!
solofalcon459 ( ) posted Fri, 25 November 2005 at 2:30 PM
I've been through the modified file 6 times looking for errors and it still only loads the first claw. I'll have to start over and see what I goofed up.
