Tue, Dec 3, 1:22 AM CST
Subject: poser and renderman
inacio ( ) posted Fri, 25 November 2005 at 1:37 PM · edited Sat, 10 August 2024 at 1:35 AM
if i save a poser file like rib (renderman) wich software will open this file?
stewer ( ) posted Fri, 25 November 2005 at 6:00 PM
In theory, every RenderMan compatible renderer should be able to read it (like PRMan, Aqsis, Pixie, RenderDotC, 3Delight, etc). In practice, there are always slight deviations from the RenderMan standard and every program interprets it a bit differently, so it may require some tweaking.
elizabyte ( ) posted Fri, 25 November 2005 at 6:06 PM
Aqsis! Hey, my husband is one of the programmers on that project. :-) As for the question, I have NO idea how a rib file saved in Poser would render. I can tell you that Poser doesn't save .obj files properly (it leaves out the transparencies!), and I dunno how well it handles other formats. One other thing to note is that with a rib file you don't really "open" it. It's more like you "send" it to the application to be rendered (I'm not explaining that very well, but I hope the point comes across). bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
lmckenzie ( ) posted Fri, 25 November 2005 at 6:33 PM
Attached Link: http://www.keindesign.de/stefan/poser/poserman.html
I've heard that Poser's .rib export is flawed or limited to some degree. I was able to render Poser .rib files with BMRT years ago when it was available. I think I had to convert the line endings in the file to Unix format but other than that no problem.
stewer ( ) posted Fri, 25 November 2005 at 6:49 PM · edited Fri, 25 November 2005 at 6:55 PM
Not any more :) With SR2, Poser 6 should also include transparencies in the exports.
Sweet! Tell him a happy user says hello. Message edited on: 11/25/2005 18:55
inacio ( ) posted Sat, 26 November 2005 at 12:30 AM
THANK YOU!
