Forum Moderators: RedPhantom
I'm ashamed to admit I haven't installed version 2 yet... just too busy! However in verson 1 both GJ and GG have nipples controlled by a single morph called "pert". It's a limited morph so you can't get out of hand with them. Also there is some distortion when the "pert" morph is used with the small breast morph, they pull slightly "wide" mike
Yes she does. That is one thing I hate about the original Jessi as well. I have a morph called no nipples, don't remember if it is part of GJ, but if you turn it down, you get better definition also. Being new to Poser, I find it odd, that V3 was/is so popular and yet the newest Jessi is so different in many ways, not so many good.
Regards, Michael
Phil, you are absolutely correct about the standard Jessi figure, something I'd never realized. Her nipples work fine. However, I was commenting on glamorous Jessi (and Glennis), no matter which genitalia setting you use the nipples work with the pert morph and they loo fine with the breast size normal ore even enlarged, however when the breast size small is set to 1 the tips of the nipples look slightly "wall eyed" and there is a small but noticeable bit of wrinkling. It's not a big deal since anyone wanting "better" detail would likely make their own morph to also get larger size, Jim's is rather modest. Also I'm not sure this hasn't been fixed in ver.2 which I still have to load. At any rate this is such a small fault, barely noticeable, and the improved bending and styling Jim put into GJ and GG is more than enough to make it worth the price! mike
Hello Thanks Jules I have seen it in CR2 of GJ2 but i find no GJ Pubic Hair.jpg no where in Poser 6 textures ;Jessie I did again RTe decoder and in the zip files created ,i don't find a file with this name .Sure i realise that i can create a dummy file with this name and place it on the texture folder.But,according to me ,this file was supposed to come with GJ2 upgrade if the CR2 call for it
No, it came with GJ, the same texture call is in GJ, so, you have to reinstall GJ (version 1). BTW, It was my mistake not to copy the full texture path from the CR2, here it is: Poser 6 Textures:Jessi:GJ Pubic Hair.jpg
Ulli
Hi folks I've turned back again to Jessi: I started to render her a lot when I purchased my P6 but she was for a time "in the dry dock". Now that Im using her again I see her potential but also her bending limits. Im seriously thinking on purchasing GJ (Ive seen ver.2 at EF). Looks like she has better joint points and the proce is nice. Only I have a question... has GJ nipples? Because is an abnormal detail I hate in original Jessi Thanks.-
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
