Fri, Nov 22, 2:06 PM CST
Subject: Help where do I load wonderwoman jpg file for V3 bodyshirt in Poser 6
rowlando ( ) posted Tue, 29 November 2005 at 7:07 AM · edited Fri, 22 November 2024 at 1:33 PM
Poser 6 wants to copy the zip file into poser6/other but this would not let me access the opend files which are jpg Rowlando
Seek what you can never loose
geep ( ) posted Tue, 29 November 2005 at 9:53 AM
cheers,
dr geep ... :o]
edited 10/5/2019
randym77 ( ) posted Tue, 29 November 2005 at 11:37 AM
Do you own the V3 body shirt? It's for sale at DAZ. If you don't own the body shirt, you can't use these textures.
rowlando ( ) posted Tue, 29 November 2005 at 7:58 PM
HI anyone again sorry to be a pain but what I am trying to do should be easy. where do I Apply texture and trans map for V3 bodyshirt
randym77 ( ) posted Tue, 29 November 2005 at 8:04 PM
It's not necessarily easy. Freebies may not have MAT files and other conveniences, and they may not follow the file structure of products which are sold. I own the V3 body shirt. Post the link where you downloaded the textures you want to use, and I'll see if I can figure it out.
rowlando ( ) posted Tue, 29 November 2005 at 8:27 PM
Here it is in Renderosity free stuff from egaeus Thanks for helping me http://www.renderosity.com/freestuff.ez?Topsectionid=0&Form.SortOrder=UserName&Start=61&Form.Search=True&Form.Criteria=wonder+woman
randym77 ( ) posted Tue, 29 November 2005 at 8:51 PM
Dr. Geep is correct. This zip does not contain MAT files or the Poser file structure. Basically, you upzip it anywhere you want, then apply the textures by hand in the Material Room. Dr. Geep's little tutorial shows you how.
My screenshot shows you how the textures should be hooked up. You have to make sure these settings are applied to all the material zones of the body shirt.
rowlando ( ) posted Tue, 29 November 2005 at 9:08 PM
I Will follow the Geeps instructions and thankyou so much for your help and time given Rowlando
randym77 ( ) posted Tue, 29 November 2005 at 9:10 PM
If you have any trouble, post a screenshot of your Material Room settings and a render of the results.
rowlando ( ) posted Wed, 30 November 2005 at 5:57 AM
HI Got it done, took me ages, as I had to repeat for every area of the bodyshirt. Well how do I save it so I can use it again and again? Also how do I make it fit as currently it will not fit V3 anything? Thanks for all your help
randym77 ( ) posted Wed, 30 November 2005 at 6:23 AM
Just save it to your Figures library. That way, you won't have to add the textures again.
Not sure what you mean when you say it doesn't fit. It's made for V3, and fits her pretty well. It also has a ton of morphs built-in.
If the problem is parts of V3 are poking through, you can probably fix it using the morph dials. For example, if her breast is poking through, setting BreastSize8 to 0.1 will often fix it.
rowlando ( ) posted Wed, 30 November 2005 at 6:33 AM
Got it saved it as you said. Rowlando
randym77 ( ) posted Wed, 30 November 2005 at 6:36 AM
Nice work!
geep ( ) posted Wed, 30 November 2005 at 8:49 AM
YES!!!!!!!!!!!
cheers,
dr geep ... :o]
edited 10/5/2019
rowlando ( ) posted Wed, 30 November 2005 at 6:28 PM
Thank you again Dr Geep your tut was fab.
geep ( ) posted Wed, 30 November 2005 at 7:20 PM
cheers,
dr geep ... :o]
edited 10/5/2019
