Fri, Nov 15, 7:24 PM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Object question
Markusthaman ( ) posted Mon, 05 December 2005 at 12:46 AM ยท edited Fri, 15 November 2024 at 5:46 PM
Hey. I have made my first models in naim8tor (needed something easy, free, and fun), and i wondererd: how do i make .obj files to .vob? cus the object files dont work in vue. is there a program for this?
Polax ( ) posted Mon, 05 December 2005 at 6:05 AM
Hi Markusthaman :) It is not clear to me what you mean by 'the object files don't work in Vue' I tried anim8tor (0.9) and the .obj obtained on object/export can be imported in Vue . also the .3ds are imported without problem. Once it is in Vue, if you choose 'save object' you'll get a .vob What version of Vue do you use ? and can you give more details on the prob you have ? Paul
Markusthaman ( ) posted Mon, 05 December 2005 at 8:08 AM
i use Vue 5 Infinite. heres my problem: i save a object from anim8tor (.obj) i open vue, press "add object", and add the folder the object is in. but it wont show up.. so i dont think the object work. i dunno. i will try with the .3ds. havnt tried yet. I will return after i tried and see if i made it. thanks for ure help so far Paul! ~markus~
Irish ( ) posted Mon, 05 December 2005 at 8:51 AM
You need to 'import' the object - load object is for Vue objects. :)
