Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 07 6:34 pm)
Attached Link: http://www.maleposer.com/
You might want to try the Reset Mat script from male poser. Freestuff.I must remember to remember what it was I had to remember.
Acadia am learning Poser5 and I do not know what you mean by bookmark. nickedshield I downloaded the reset mat script and read the readme file and do you know if the rewritten mat becomes the default mat or when I close and re-open Poser5 again will it default back to Poser5's default mat? any other ideals for the effect to render?
The reason why you see it as white is because you're not looking at it in textured mode (the little balls under your pic, the rightmost one is Textured mode. Click that, and it will loo like your render) Go to the Material Room and unplug all the nodes, then you'll be left with a white model that will render white.
And Acadia's "Bookmark" just means s/he wants to follow this thread and get an ebot whenever someone answers :o)
Most scripts that I've used act on whatever is in the scene which means when you launch Poser again you'll probably have to run the script again. There were a few more scripts for Poser5 at male poser that you should look at, pertaining to node build up, which ernyoka1 was referring to.
I am using Poser5 and what I want to do is when I beging working a character is to have it render white with shades of grey and black shadows. Can you trun off the materials for rendering? I have gotten an effect like I mention using the lights but when I render it it adds the material. Here is a pic of it
