Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Lighting effects are very good. I think the kickback is set into motion a little too early. Now it seems like he's pulling back the gun while shooting. The sound effect sounds fine, and it times well with the blasts. Cool animation!
There's shots where I'm almost sure he isn't looking at the target, and the blaster bolt doesn't seem to go in quite the direction the gun is pointing. The first shots look a lot more convincing than the later shoot-from-the hip styles. With all the apparent recoil, I'd be betting on the barn door for those latter shots. There really is too much body movement for accurate shooting. It needs to be toned down.
Attached Link: Need Feedback on M3 Battle Animation...
Need some feeedback on an animation Im working on.. Michael 3 with Utilize armor and Motion Capture bvh applied blasting away..Particularily the sound intergration with the blaster..
