Fri, Jan 24, 4:44 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: HELP! URGENT! Can someone spot the error?!
TrekkieGrrrl ( ) posted Thu, 15 December 2005 at 2:41 AM · edited Thu, 09 January 2025 at 7:34 AM
I mean.. there must be an error here somewhere, but I can't for the life of me see what it is :o( I need this one rendered 30 minutes ago... I've tried with Normals Forward on and off. No difference. The lights are my default lights , one raytraced shadows-light, 2 lights without shadows. If I load another character into this scene, it renders ok. HELP?!
Fugazi1968 ( ) posted Thu, 15 December 2005 at 3:28 AM
ambient colour is black and value 1, set value to 0.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
TrekkieGrrrl ( ) posted Thu, 15 December 2005 at 4:01 AM
I tried that :( It made no difference :(
LostinSpaceman ( ) posted Thu, 15 December 2005 at 4:03 AM
Go towards the light Carol Anne! I'd suggest you check the settings on your lights to make sure a Negative vallue hasn't slipped in. Poser 6 does have that ability to suck light out of a render these days you know with negative settings.
Fugazi1968 ( ) posted Thu, 15 December 2005 at 4:09 AM
ok the ambient thing needs doing, but you may also be having trouble cos of the spectacular settings. try setting the spectacular colour to white, then reduce the spectacular value and highlight size values.
TrekkieGrrrl ( ) posted Thu, 15 December 2005 at 4:11 AM
Mizrael, I've checked the lights :o/ Other characters I load into the scene renders fine. Fugazi.. I'll try that :) Carol Anne?! who's that?! LOL
TrekkieGrrrl ( ) posted Thu, 15 December 2005 at 4:21 AM
Dammit.. Setting Specular to white didn't help. And setting the Ambient to 0 only makes it render TOTALLY black. I checked the lights once again. All are at an intensity at 1. I wonder if something has gone corrupted in this one. It was a saved PZ3. I reloaded the character and it rendered as it should. The one that is making trouble originally had the Real Skin Shader attached, I just unplugged all the nodes corresponding to that. Might be the reason. But it rendered with that same burned colour also WITH the Real Skin Shader in place... :o( The problem with my RENDER is solved because I loaded a new character. But I'm still stumped here. I guess something went awry in the cr2 then...
LostinSpaceman ( ) posted Thu, 15 December 2005 at 5:09 AM
Carol Anne was the little girl in the Movie Poltergeist that went into the TV Closet with the spookies. "Go Into he Light Carol Anne" was a very famous line from the movie. :P
richardson ( ) posted Thu, 15 December 2005 at 5:09 AM
I'm guessing the skin shadre was saved to character while she was spun 180 degrees to this axis...You need to rerun the script with this light setup.
TrekkieGrrrl ( ) posted Thu, 15 December 2005 at 5:25 AM
@ Mizrael: Aha! I don't watch horror movies. They're bad for my sleep... GG @ Richardson: Hmm that could be. But now that all the Real Skin Shaders are unplugged.. should that matter then?!
richardson ( ) posted Thu, 15 December 2005 at 5:41 AM
Nope. My bad. I thought maybe you screenshot(ed) after the disconnect.
williamsheil ( ) posted Thu, 15 December 2005 at 6:19 AM
Is it actually a figure or have you just imported the mesh as a prop for texturing? Sometimes in the past I've had situations where the Poser lights don't seem to work if there's no actual figure in the scene. It surprised me because I'm not sure if its been a consistent feature or whetehr it's also related to light shaders or shadows. I never got round to investigating the exact circumstances. If it is a prop mesh try dropping a test figure in and moving it away from the camera. Bill
maxxxmodelz ( ) posted Thu, 15 December 2005 at 6:54 AM
Does it still render like this if you turn off raytrace in the render settings? What is the shadow bias on your light that has shadows enabled?
Dave ( ) posted Thu, 15 December 2005 at 7:39 AM
Shouldn't lights be at 100% and not 1%? David
Anniebel ( ) posted Thu, 15 December 2005 at 10:19 AM
You haven't used dynamic clothes have you? This happened to me when I saved a file with dynamic clothes. As soon as I went into the cloth room & activated the final frame again, all was ok - when the scene loaded it was with the inital frame rather than the end frame.
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
TrekkieGrrrl ( ) posted Thu, 15 December 2005 at 12:25 PM
No dynamic clothes. As I said, if I put another character in the scene it is properly lit, so it's not the lights, it's something with this character (and it's aPoser character btw, it's PoserWorks Amy :o) )
PapaBlueMarlin ( ) posted Thu, 15 December 2005 at 3:39 PM
Remove the textures from the figure and apply plain colors. Then do another render. Than way you can tell if the issue is with the materials or with the render engine.
TrekkieGrrrl ( ) posted Thu, 15 December 2005 at 4:03 PM
I think it is the materials. I eventually loaded the character fresh from the folder instead of using saved version (with hair), and it works ok. I guess something has gone wrong at the cr2 level. I was mostly curious if anyone could immediately spot something I'd overlooked. But as none of the (otherwise great) suggestions work, I've come to the conclusion that there must be some sort of error in my saved cr2.
